Switch XMG-108 and XMG-108HP
server3
server3 Posts: 3  Freshman Member
I have 4 of these switches connected in series. The LEDs indicate LOOP between them. The network works. I tried connecting the switch to the switch with a cat7 cable and a 10gbe optical cable and it still indicates a loop (the green LED blinks slowly)
even if I connect two switches to each other and nothing else is connected, it automatically indicates a loop.
Is this normal?
I haven't found anything about it anywhere.
Thanks, who knows what it is.
  • server3
    So the engineers must have made a mistake somewhere. Never mind, it works so I'll leave it at that.
    Thank you for your answer :)
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,697  Zyxel Employee
    Hi @server3,
    This is a known issue in the XMG100 series. It enables loop detection but accidentally recognizes the loop probe packets from other XMG100 series as from itself when the XMG100 series connects.
    The traffic will be forwarded without issue since this is the loop detection behavior.
    Zyxel Melen
  • server3
  • Zyxel_Melen
    Update:
    This issue has been fixed in the newly manufactured device. You may check if your serial number is after the serial in the below table.
    Model
    SN from
    XMG-105
    S244322003111
    XMG-108
    S244328017995
    XMG-105HP
    S244318000001
    XMG-108HP
    S244318000501
    Zyxel Melen
  • BernhardS
    BernhardS Posts: 3  Freshman Member
    edited April 21
    (double post deleted)
  • BernhardS
    Is there a way to update/replace existing devices that exhibit this issue?
  • Zyxel_Melen
    Hi @BernhardS
    You may apply RMA request to get a replacement.
    Please reference this FAQ to submit RMA request:
    Zyxel Support Portal [RMA] - Claiming Warranty Service for a Zyxel Product? – Zyxel Support Campus EMEA
    Zyxel Melen
  • server3
    I started this thread a while ago with this problem.
    I asked the seller for a replacement and there was no problem with it. They sent me other devices. The newer ones also have flow control button.
