Wireless Bridge only in 5 GHz band
We have two NWA55AXE AP acting as wireless bridge between two cable network segments. The wireless link appears to be congested, as 2.4GHz radio is up to 75% occupied.
Is there any way to use 5GHz band to stablish the link, or any way to disable 2,4 GHz radio only in this two APs?
Hi @felix_santiago,
Update:
Smart mesh setting can select the band you prefer.
Could you help to enable Zyxel support so we can help to check?
Zyxel Melen0
Thanks. We are managing this APs remotely via Nebula, and I'm not able to find where to disable one radio, that's what I would like to do.
Cloud you please help me in finding the correct way to disable a radio via Nebula?
Hi @felix_santiago,
Update:
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
