Can I activate MLO in NWA130BE
Updated on August 7, 2025:
Zyxel WiFi 7 Access Points now support the MLO (Multi-Link Operation) feature in Standalone mode starting from firmware 7.20P1 (released on July 28, 2025).
When the radio mode is set to 802.11be, MLO will be automatically enabled.
*Additionally, all management modes support MLO on WiFi 7 models now:
- Standalone mode (MLO supported since firmware 7.20p1)
- Controller-managed mode (MLO supported since firmware 7.20p1)
- Nebula cloud-managed mode (MLO supported since firmware 7.00p1)
Zyxel Melen0
Zyxel Melen0 -
Hi @Zyxel_Melen, thank you for your response.
My follow up question would be, apart from setting the WPA3, what can be list of configuration I need to keep to experience MLO? In terms of Advanced settings and Radio Configuration.0
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
