Armor blocking some websites and apps
muffinman8861
muffinman8861 Posts: 1 image  Freshman Member
Hi, this morning my router started blocking some websites and apps but not everything. The apps just say no connection and the websites state SSL errors. If I use mobile data or a VPN then I can access with no issues which had lead me to believe it is an issue with the router.
Parental control is switched off so it isn't blocking any connections.
  • bahecz44120
    bahecz44120 Posts: 100 image  Ally Member
    First Comment First Answer
    check with the retailer about it and see if there is software version to update or newer version for your home router.
