EX3301-T0: Set up as Access Point, does it support setup as a wireless client or bridge mode?
I have an EX3301-T0 provided by my ISP, RocketFibre. I've set it up as an access point with my TP-Link Archer AX-53 router and RE700X extender in a mesh network. The EX3301-T0 is configured not to be part of that network but a separate one, which I've set up.
Setting up the access point was quite straightforward, and it works fine in that everything can connect successfully to it, but without internet access.
I was working through ideas to solve this, eg, configure the EX3301-T0 as a wireless client or in bridge mode to allow it to connect to the TP-Link router’s wifi network and share that connection via its LAN ports and wifi. But I can't find any settings in the admin interface to enable this. Does anyone have insight on this?
More importantly, perhaps, is this - does the EX3301-T0 actually support set up as a wireless client or in bridge mode?
Thanks.
if without TP link setup, you are able to get internet, then probably need to check TP link Mesh setup. usually, there is mode you can choose to connect behind as what you want for your network to be set up with. check each of mode description and see whcih mode suit your network.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
