DHCP and Secondary IP
PeterUK
PeterUK Posts: 4,405 image  Guru Member
It CAN be possible older models do it!
when you do a routing rule
incoming LAN
next hop WAN 2
SNAT outgoing-interface which will be the the DHCP IP
Or in my setup also
incoming WAN to Secondary IP 192.168.254.1
Source Address 192.168.252.0/23
next hop WAN 2
with Static route
192.168.252.0 255.255.254.0 gateway 192.168.254.2
1 votes
Active · Last Updated
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @PeterUK ,
    To better assist you, please provide the following information:
    1. Which firewall model do you need this routing function for?
    2. What is your specific use case or business requirement for this routing function?
    3. You mentioned that some models already support this function. Could you:
      • Specify which model(s)
      • Share a screenshot of the existing configuration
    Zyxel_Judy
    Untitled Image
    edited January 2025
    Its the FLEX200 H and on a early version of the firmware it was possible see case #456511
    The specific use case was that it worked and I used it and now have had to set it up another way which means a extra port was needed
    It was done on a Zywall 110 which was replaced for more testing with FLEX200 H
  • Zyxel_Judy
    Hi @PeterUK ,
    Thank you for your interest. We are still evaluating this feature. We will announce it in our Firewall News & Release section if it becomes available in the future.
    Zyxel_Judy
    Untitled Image
