Recovery Steps for USG FLEX/ATP Series Application Patrol Signature Issue (Jan. 2025)
Hi, I was able to enter debug mode using a new cable and recovered successfully device 1.
The working Flex500 (device 2) is working correctly with 20250123, any way to update to issue-free App-Patrol version avoiding the date code firmware (I repeat, the device is working correctly)? If I try to update App-Patrol version (20250123) on the working device I have no update because this is the last one (but faulty version).
If you publish a new non-faulty App-Patrol version on the cloud we can download it automatically overwriting 20250123 with no need date code firmware.
Then I will activate HA.
Ticket 485508.
Andrea
I have deleted the faulty app patrol signature et reinstall the latest firmwar, when I update app patrol signatures I only get
1.0.0.20241205.0 , why ?0 -
Today, ZYXEL USG FLEX 100, fw V5.39(ABUH.1), App-Patrol signature1.0.0.20250123.0, affected by this issue, with many reboots since 03:00 a.m. 25/01/2025, with the web interface not responding and remaining active for a few minutes after a reboot.
After a manual shutdown, I simply tried updating the App-Patrol signature in CONFIGURATION > Licensing > Signature Update and after giving error, I found that the signature version was back to 1.0.0.20250102.0.
I immediately performed a reboot. The App-Patrol signature version remained 1.0.0.20250102.0.
Now the Zyxel USG FLEX 100 remains on and the CPU utilization has normal values.
Was it enough to simply do this?
Marco0 -
I have the same problem
Hi @BZM @marcopessina @RobertM67 ,
If you are still experiencing issues following the recovery process, please get in touch with our Security team for help.Thanks.
Ivan
How can I reboot the USG (Flex 700) without the the web interface? We have tried to press the reset button without success.
Multiple reboots, update signatures, etc.
If the only "recovery" is to be on-site at each unit and do a console-FTP recovery, im unfortunately done. You guys screwed me hard with the last failed firmware update and now this…
I get that eventually every manufacturer makes a mistake, even the big ones in the market. Its like bananas: homogeneous deployments can reduce knowledgebase and training but when the vendor fails (parasite), they all fail.
Physical power cycle is all that has worked for us. No commands will reboot the device.
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
