Recovery Steps for USG FLEX/ATP Series Application Patrol Signature Issue (Jan. 2025)
124
  • AndB
    AndB Posts: 3  Freshman Member
    Hi, I was able to enter debug mode using a new cable and recovered successfully device 1.
    The working Flex500 (device 2) is working correctly with 20250123, any way to update to issue-free App-Patrol version avoiding the date code firmware (I repeat, the device is working correctly)? If I try to update App-Patrol version (20250123) on the working device I have no update because this is the last one (but faulty version).
    If you publish a new non-faulty App-Patrol version on the cloud we can download it automatically overwriting 20250123 with no need date code firmware.
    Then I will activate HA.
    Ticket 485508.
    Andrea
  • BZM
    BZM Posts: 2  Freshman Member
    I have deleted the faulty app patrol signature et reinstall the latest firmwar, when I update app patrol signatures I only get
    1.0.0.20241205.0 , why ?
  • march2o
    march2o Posts: 2  Freshman Member
    Today, ZYXEL USG FLEX 100, fw V5.39(ABUH.1), App-Patrol signature1.0.0.20250123.0, affected by this issue, with many reboots since 03:00 a.m. 25/01/2025, with the web interface not responding and remaining active for a few minutes after a reboot.
    After a manual shutdown, I simply tried updating the App-Patrol signature in CONFIGURATION > Licensing > Signature Update and after giving error, I found that the signature version was back to 1.0.0.20250102.0.
    I immediately performed a reboot. The App-Patrol signature version remained 1.0.0.20250102.0.
    Now the Zyxel USG FLEX 100 remains on and the CPU utilization has normal values.
    Was it enough to simply do this?
    Marco
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 348  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Hi @BZM @marcopessina @RobertM67 ,
    If you are still experiencing issues following the recovery process, please get in touch with our Security team for help.
    Thanks.
    Ivan
  • SHA_M
    SHA_M Posts: 4  Freshman Member
    How can I reboot the USG (Flex 700) without the the web interface? We have tried to press the reset button without success.
  • MikeForshock
    MikeForshock Posts: 52  Ally Member
    Multiple reboots, update signatures, etc.
    If the only "recovery" is to be on-site at each unit and do a console-FTP recovery, im unfortunately done. You guys screwed me hard with the last failed firmware update and now this…
    I get that eventually every manufacturer makes a mistake, even the big ones in the market. Its like bananas: homogeneous deployments can reduce knowledgebase and training but when the vendor fails (parasite), they all fail.
  • MikeForshock
    Physical power cycle is all that has worked for us. No commands will reboot the device.
