Do NWA1123-AC HD have the ability to use Scheduled Reboot Function?
50+ AP's across site.
We would like to schedule a reboot of all AP's out of hours. We currently use the Nebula Control center and when going onto the system to set this up using the guide (https://community.zyxel.com/en/discussion/21666/introducing-scheduled-reboot-for-ap-and-mobile-routers-a-step-towards-enhanced-efficiency) it doesn't display a maintenance option within the status page on each AP.
Do NWA1123-AC HD need to be on a certain firmware version? (Currently on V6.25)
Thank you
Hi @Kyle_Kimberley,
NWA1123-AC HD doesn't support this feature in any of its firmware versions. However, you have a replacement to use the PoE schedule on your PoE switch if PoE powers up your NWA1123-AC HD.
Zyxel Melen0
Hi @Kyle_Kimberley,
Zyxel Melen0 -
You could achieve something similar via SSH/Telnet function, if Nebula management allow local access.
Expect/TCL could be a useful tool to manage this kind of scripted action, but will need a device allowed to connect to port 22/23. I strongly advise against public SSH/Telnet access.
@Zyxel_Melen correct me if I'm wrong: at web GUI the command is available, and as cli the command is available (Section 24.3 of CLI reference guide Version 6.1. Edition 3, dated 09/2020)
Nebula should only deliver the command at scheduled time.0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
