VPN on reduces speed dramatically
Wookie_316
Wookie_316 Posts: 1 image  Freshman Member
On my router Zyxel EX3301-T0 there is no options for vpn access I can find. When use any devices using the vpn own apps , it definitely works but hammers my speed by over 50% when it didn't with another router and connection. So wasn't sure if there's any settings at router that is suppressing it as when vpn is off I get regular fast speeds by ISP. Any help would be appreciated
  • bahecz44120
    bahecz44120 Posts: 100 image  Ally Member
    First Comment First Answer
    Hi, try to set firwall to low and see if speed gets back with VPN enable.
