Help Needed: Setting up VPN on Zyxel EX3220-T0 Router
gabrielmoraesp
gabrielmoraesp Posts: 1 image  Freshman Member
Hi everyone!
I need assistance with setting up a VPN on my Zyxel EX3220-T0 router. The goal is to use the VPN so my TV can access streaming content that’s only available outside my country of residence.
I’m unsure about:
  1. How to install the VPN on this router (do I need any specific firmware?).
  2. The main settings I need to configure.
  3. Whether it’s possible to use services like ExpressVPN, NordVPN, or others directly on the router.
Any guidance, tips, or helpful links would be greatly appreciated! 🙏
  • bahecz44120
    bahecz44120 Posts: 100 image  Ally Member
    First Comment First Answer
    you can use VPN application (example NordVPN) to reach out service outside of your residence. No need to configure VPN on router itself. tho, you can lower firewall from medium to low if you are having difficitulity passing traffic.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @gabrielmoraesp
    Welcome to the forum.
    I have not been able to find a user guide but have found specifications at https://loja.dicomp.com.br/roteador-zyxel-ex3220-t0-dual-band-ax1800-wi-fi-6/30645/p
    The specifications talk about VPN pass through, so you can not setup VPN on the device itself.
    You will need to set-up VPN on the devices at client and destination network, rather than on the Zyxel device.
    I hope that this is helpful.
    Kind regards Tony
