ZyXEL Configure Converter VPN100 to Flex200
Hi
Noticed at:
convert.cloud.zyxel.com
I can convert VPN100 only to Flex 200H or Flex200 HP.
I happen to have Flex 200. Is there a way to have my VPN 100 configuration converted to Flex 200?
You're correct. There are no tools or workarounds available to convert the configuration from VPN100 to FLEX200.
Zyxel_Judy
Hi @Rimfire ,
The Zyxel Security Appliance Configuration Converter helps convert configurations from:
- Legacy appliances (USG/ZyWALL) to newer ZLD firmware devices
- VPN/ATP/USG FLEX to the latest uOS firmware (USG FLEX H series)
Please note that there is no tool available to convert configurations from VPN to USG FLEX.
Zyxel_Judy
Thanks,
just to be sure:
1. There isn't a converter for VPN100 to Flex200?
2. There isn't a work around to convert the VPN100 konfiguration to Flex200?
The plan is to skip Nebula mode due to complexity of the configuration.0 -
Has it never existed, or did it exist some years ago (before H series)?
Zyxel_Judy
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
