NWA130BE new FW 7.10(ACIL.1)C0 fail to use.
Hi @Stp,
After a quick check, I noticed that the uplink is different in your test results. On NWA130BE, it goes to True online; but on other AP, it goes to AIS. Since different ISP might have different result, please use the same uplink to test.
Second, your radio country setting is different from your site location setting. Is it possible to set it with correct country?
Zyxel Melen0 -
I use 2 WAN. Router was automatically selected. And before upgrade, this configuration can use perfectly. It failed after V7.10. I hated ZYXEL!!! DO YOU CAN HELP? DO YOU TEST YOUR SYSTEM?
I config as Standalone in MY COUNTRY. IT CAN’T FIX IT!!!0 -
Here's my lab's result with NWA130BE with firmware version V7.10(ACIL.1) (Latest):
And since you get bad speed test result when running different firmware version, this issue is more likely not related to AP but other issue. Please help to:
- Test again with the same uplink that you tested for other AP.
- If the issue is still the same, please help to provide your topology. If the uplink of NWA130BE is our switch, please help to collect tech support so we can check further. You can send the tech support to me via private message.
https://community.zyxel.com/en/discussion/21237/switch-how-to-collect-the-tech-support-info-on-v4-80-firmware-version-and-newer
Zyxel Melen0 -
And also collect the AP diagnostic after testing speed test.
How to collect the Standalone AP diagnostic info by GUI? — Zyxel Community
Zyxel Melen0 -
I’m not sure, or I must RMA for my device. Did device fail after upgrade FW? I restored V7.0P3, but It didn’t work correctly.
I checked LAN port on NWA130BE and XS1930. I changed from Zyxel PoE12-60W to MikroTik PoE port, speedtest normally. I resetted port on XS1930. Now, it's working perfectly on 7.1P1 FW. Thank you.
- 441 Beta Program
- 210 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
