Default settings in nebula ?
Mr_IT_4_Life
Mr_IT_4_Life Posts: 13 image  Freshman Member
How to factory reset all settings to default values in nebula cloud management ?
I need to reset all settings to troubleshoot network issues, but can`t find any where to reset them all besides manually factory reseting every device attached!
all help is appreciated. ☺️
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @Mr_IT_4_Life,
    Nebula does not have a button to reset all Nebula settings to default values currently. But you can use the Organization-wide manage > Change log to check the configuration you have changed, or move the device to a new created site.
    Hope it helps.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Mr_IT_4_Life,
    Hope it helps.
    Zyxel Melen
  • Life_Alex
    Life_Alex Posts: 5 image  Freshman Member
    Hi, just a quick follow up question, on your latest response @zyxel_melen how can I use change log if I don`t have Pro Licences on all of my devices ?
  • Zyxel_Melen
    Hi @Life_Alex,
    I apologize for not mentioning this earlier - the change log feature is only available with the Pro organization. Unfortunately, this means you'll need Pro licenses for your devices to access this functionality.
    Zyxel Melen
Nebula Tips & Tricks
