NWA55AXE Pole Mount Kit
Best Answers
Hi @SkyGoat,
No, NWA55AXE is not compatible with the ACCESSORY-ZZ0106F pole mount kit since the screw design. In addition, the antenna of NWA55AXE is omnidirectional, therefore, you don't need this mount kit to help adjust the antenna angle, which is the main purpose of this mount kit.
Zyxel Melen0 -
Hi @SkyGoat,
I apologize for the delayed reply I was checking with our product team.
The answer is 100 meters. The NWA55AXE is designed with an omnidirectional antenna, primarily for expanding wireless coverage rather than establishing long-distance point-to-point connections. Given the 1KM distance between the two buildings, this setup is not suitable, as omnidirectional antennas are not optimized for focused, long-range transmission.
Zyxel Melen0 -
Hi @SkyGoat,
It is the same as NWA55AXE, 100 M. In addition, this range is the maximum range with the Zyxel antenna. You may reach a further distance if you change with a directional antenna.
Zyxel Melen0
Hi @SkyGoat,
Zyxel Melen0 -
Thanks Melen.
What is the maximum range of 2 NWA55AXE's operating in wireless bridge mode?
I have a two buildings 1km apart that I would like to bridge.
Hi @SkyGoat,
Zyxel Melen0 -
@Zyxel_Melen
Thanks Melen.What is the range of two WAX655E in wireless bridge?
Hi @SkyGoat,
Zyxel Melen0
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 484 News and Release
