XGS1930-24 External Traffic problem
2»
  • tczauderna
    tczauderna Posts: 30 image  Freshman Member
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
    that's how it looks. However, as I mentioned, the exact same config is on the laptop with only a different IP and there is no problem.
    Additionally, you can see in the technical logs of the switch that there is no default gateway.
    Other switches have no problems.
    on UTM in the logs there is no information about blocking anything
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,257 image  Zyxel Employee
    edited February 20
    Hi @tczauderna,
    After checking the tech support, we found this could be related to management IP configuration. Since you have the static IP address, the configuration should remove the "ip address dhcp-bootp" configuration. But somehow the switch didn't. This causes the management IP duplication and causes the switch can't access the Internet. Let me provide you with a corrected configuration file for you to restore it. Then the switch will connect to Nebula in a few minutes.
    Zyxel Melen
