GS1900-8 Time Range
I would like to buy a GS1900-8 switch.
First, I would like to have more explanation about the Time Range.
I would like to be able to automatically turn off port "5" at 9 p.m., and turn it back on at 8 a.m.
Reading the instructions, I have the impression that all the ports on the switch are blocked.
Is my choice of switch compatible with this function?
Thanking you in advance for your clarifications
Sincerely
Bibi49
PS sorry for google translate
Hi @Bibi49,
Thanks for your feedback. I have helped create an idea post and we will monitor this idea post to evaluate it.
GS1900-8 Time Range for enable/disable port function — Zyxel Community
Zyxel Melen0
It is possible to use Time Range for individual PoE port to enable/disable PoE power on that port.
I don't see this function available to enable or disable non PoE port.
For me, this will become a very important function in order to limit the connection of children.
Is there a switch (at a reasonable price) that has this function (turning off a not POE port at a specific time) ?
Is this a feature that could be added in a future update ?Thank you for your answers and for your responsiveness. 😉
There is no disable port but ACL can block at given times your best options are GS2220-10 or GS1920-24v2
If problem is wifi a cheaper option is a AP with Schedule like the NWA50AX Pro
OR for a poor mans timer get a 5 port switch and a smart plug
It is not for wifi.
"OR for a poor mans timer get a 5 port switch and a smart plug" ⇒ The switch don't like On/Off 2 time /day.
I bought a GS1200-8 (to discover Zyxel: I find them quite good) a week ago, you can manually deactivate a port.
I find it a shame that even a more efficient model (GS1900-8 or GS1915-8) cannot do it at scheduled times.
Hi @Bibi49,
Zyxel Melen0 -
Thank's Melen
I am ordering the GS1900-8 immediately.
I hope this feature will be added
- 217 Nebula Ideas
- 583 USG FLEX H Series
- 297 Service & License
- 476 News and Release
