XGS1930-24 External Traffic problem
that's how it looks. However, as I mentioned, the exact same config is on the laptop with only a different IP and there is no problem.
Additionally, you can see in the technical logs of the switch that there is no default gateway.
Other switches have no problems.
on UTM in the logs there is no information about blocking anything0 -
Hi @tczauderna,
After checking the tech support, we found this could be related to management IP configuration. Since you have the static IP address, the configuration should remove the "ip address dhcp-bootp" configuration. But somehow the switch didn't. This causes the management IP duplication and causes the switch can't access the Internet. Let me provide you with a corrected configuration file for you to restore it. Then the switch will connect to Nebula in a few minutes.
Zyxel Melen0
- 603 USG FLEX H Series
- 481 News and Release
