port led switch gs1920 off
DarioVedovati
DarioVedovati Posts: 1 image  Freshman Member
Third Anniversary
Hi i'm working on new switch gs1920 i did the configurazione but when i put the cable in any port i can't see the led on everythink seems work correctly.
There is an option i can look to enable it?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,603 image  Zyxel Employee
    Hi @DarioVedovati,
    Please check the following troubleshooting items:
    1. Physical Connections: Double-check that all cables are securely plugged into both the switch ports and the connected devices. Ensure there are no bent or damaged pins on the connectors.
    2. PoE Mode Button (if applicable): Some GS1920 models, particularly the PoE versions, have a button that toggles the LED display between PoE status and link speed. Ensure this button is set to display link speed.
    3. Loop test: Connect two ports as a loop to check the port functionality.
    Zyxel Melen
