[NEBULA] How can I allow RDP through when using IDP prevention
Terminal Server is on network with RDP port forwarded by NSG100. If NSG100 has IDP Detection box checked, remote TS users can connect. Once the IDP Prevention box is checked, incoming RDP connections are blocked.0
Hello @PBE
You can create the firewall rule for the exception.
Action "allow" From source "any or specific IP" to destination "RDP IP" Dst port "RDP service port"
Hope it can help you out.
/Chris0 -
Thanks Chris, but if i understand things correctly, once the NAT port forwarding is in place, it automatically creates the firewall rule in the NSG100. The port forwarding and firewall configuration works perfectly when the "Prevention" feature of IDP is off so the firewall is letting the traffic through I only have the problem when "Prevention" is on.0
The IDP will not check the firewall rule which you have create it manually, could you please give it a try and feel free to let me know if still not work, thanks.
/Chris0 -
It worked, thanks1
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
