backup?
BACHTELEN
BACHTELEN Posts: 5  Freshman Member
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,561  Zyxel Employee
    Hi @BACHTELEN,
    Nebula supports configuration management(Pro function), which allows you to back up/restore site-wide configuration. Since most AP configurations are site-wide, you can use configuration management to back them up.
    Zyxel Melen
  • BACHTELEN
    Is there any possibility to backup the whole Organisation in Nebula, including all AP Configs?
  • Zyxel_Melen
    Hi @BACHTELEN,
    Zyxel Melen
Nebula Tips & Tricks
