USG40W - When entering a website (www.idrive.com) I get redirected to the firewall login
laltobelli
laltobelli Posts: 24  Freshman Member
First Comment Sixth Anniversary
When trying to access the website www.idrive.com on any PC on the network the page gets redirected to the login screen for the USG40W. We found this issue when trying to get Cloud Replication (Backup) working on the iDrive BMR device. THe site *.idrive.com is listed as a Trusted website in the Content Filter.
Larry
  • laltobelli
    The problem had to do with a port forwarding rule I put in. Disabling the rule allowed the website to open.
«1
    PeterUK Posts: 3,890  Guru Member
    what does this show?
    nslookup www.idrive.com
  • laltobelli
    Server: localhost
    Address: 127.9.0.1
    Non-authoritative answer:
    Address: 148.66.234.46
    whats with DNS being by localhost 127.9.0.1 ?
  • laltobelli
    Sorry, typo it was 127.0.0.1
    edited February 25
    Ok but still that means your not DNS to Zywall or some DNS like 8.8.8.8 so your DNS to your PC that then DNS so do you know why that is?
    It would seem your PC is setup to 127.0.0.1 for DNS which might be a red flag if you don't know why get to your network setting and change to use the router LAN gateway IP as DNS or 8.8.8.8 or other DNS
  • laltobelli
    It is a server running DNS for a domain.
  • valerio_vanni
    valerio_vanni Posts: 156  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    On an address reserved for loopback?
    Have you tried to use local (regular) address of DNS server (10.10.10.5, 192.168.1.20 etc)?
  • laltobelli
    Sorry about the delay in getting back. I wanted to go onsite to do this. After changing the DNS to 8.8.8.8, flushing the DNS, rebooting and clearing the cache on the browsers the problem did not go away. Below is the output of ipconfig before and after the DNS change and the nslookup results:
    Before changing DNS to 8.8.8.8
    Ethernet adapter Local Area Connection:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Intel(R) 82579V Gigabit Network Connection
    Physical Address. . . . . . . . . : 4C-72-B9-43-80-E7
    DHCP Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    IPv4 Address. . . . . . . . . . . : 192.168.1.95(Preferred)
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Lease Obtained. . . . . . . . . . : Monday, February 17, 2025 11:01:43 AM
    Lease Expires . . . . . . . . . . : Saturday, March 01, 2025 11:01:37 AM
    Default Gateway . . . . . . . . . : 192.168.1.4
    DHCP Server . . . . . . . . . . . : 192.168.1.4
    DNS Servers . . . . . . . . . . . : 192.168.1.6
    192.168.1.4
    208.67.220.220
    NetBIOS over Tcpip. . . . . . . . : Disabled
    C:\WINDOWS\system32>nslookup www.idrive.com
    Server: FHSERVER.FANDHACCTG.LOCAL
    Address: 192.168.1.6
    After changing DNS to 8.8.8.8
    C:\WINDOWS\system32>ipconfig /flushdns
    Windows IP Configuration
    Successfully flushed the DNS Resolver Cache.
    C:\WINDOWS\system32>ipconfig /registerdns
    Registration of the DNS resource records for all adapters of this computer has been initiated. Any errors will be reported in the Event Viewer in 15 minutes.
    C:\WINDOWS\system32>ipconfig /all
    Host Name . . . . . . . . . . . . : FNH-PC2
    Primary Dns Suffix . . . . . . . : FANDHACCTG.LOCAL
    Node Type . . . . . . . . . . . . : Hybrid
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    DNS Suffix Search List. . . . . . : FANDHACCTG.LOCAL
    Lease Expires . . . . . . . . . . : Saturday, March 01, 2025 3:11:59 PM
    DNS Servers . . . . . . . . . . . : 8.8.8.8
    Ethernet adapter Ethernet:
    Media State . . . . . . . . . . . : Media disconnected
    Description . . . . . . . . . . . : TAP-Win32 Adapter OAS
    Physical Address. . . . . . . . . : 00-FF-23-E2-30-24
    Server: dns.google
    Address: 8.8.8.8
  • laltobelli
    I cleaned the content filter, as in the article. It made no difference. I also tested the content filter and it does not appear to be working properly. It apppears to be configured properly but I am looking into why it does not appear to block sites in any of the catergories.
