Change default admin password not working
ATP 500
The procedure for resetting the admin password does NOT work.
https://support.zyxel.eu/hc/it/articles/360012744371-Cosa-posso-fare-se-ho-dimenticato-la-mia-password-USG-FLEX-ATP-VPN-o-non-riesco-pi%C3%B9-ad-accedervi#two
ATKZ -g
ATGO
the password should be 1234 but on the next reboot entering these credentials nothing happens (on WEB GUI). It does not allow me to change the password like the first installation. Tried on EDGE and on CHROME.
How change admin password via Command Line Interface (CLI) ?
What to do?
THanks
Problem solved!
Need to reset the password to 1234 usingATKZ -g
ATGO
Then follow these instructions (also works on ATPxxx)
https://mysupport.zyxel.com/hc/en-us/articles/360007955939--ZLD-How-to-add-new-Admin-account-CLI
Of course you need access via interface with special cable and Tera Term
You can close the thread
ThanksD.
can I use the following command on the ATP500 for changing password admin user ?username <existing_user> password <new_pass> user-type admin'
D.
Problem solved!
ATGO
ThanksD.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
- 106 Security Highlight
