Which port to use in bridge mode
saltet
saltet Posts: 76 image  Ally Member
edited February 2025 in Nebula
Hi.
I have several NWA130 be.
two of them have I enabled wireless bridge mode.
Using Nebula
when connecting a device to the ap with cable which port should I use - uplink or lan ?
Neither of this two ap is the root ap connected to the router. Do also the root ap needs to be in wireless bridge mode to get it working ?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    Hi @saltet ,
    LAN port.
    Both the Root AP and Repeater AP need to have Wireless Bridge enabled and support this feature for it to work properly.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @saltet ,
    LAN port.
    Zyxel_Judy
    Untitled Image
  • saltet
    Thanks a lot for your answer. This service for help which you provide is excellent
Nebula Tips & Tricks
