need interface rate limiting
Hi @PeterUK ,
I did try using BWM for interfaces WAN1 and DMZ that are in a bridge and it did not rate limit that way
Is the issue that the BWM feature isn't functioning properly with your current settings, or that you're unable to configure different bandwidth limits for each individual interface as you need to?
Zyxel_Judy
Both but I'm saying to look at just BWM this does not rate limit set at 1Mb download and upload where DMZ and ge1 are in a bridge
Hi @PeterUK ,
Thank you for your input. We will continue to monitor the user's requirements and evaluate this.
Zyxel_Judy
So in V1.32 you have remove being able to add interfaces of a bridge in BWM but my old test rule was still showing up and it did limit from DMZ to ge1 download 1Mb but not the upload so I hope to see being able to do this in the future along with total interface limiting.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
