Device and config for port failover setup for two identical pcs controller
I have to configure 2 identical controller PCs in the same rack, the first as master and the second as slave, to manage sensors. They must have the same IP address (identical controller PCs).
I need a failover setup to set up on a single switch/router to make sure the secondary comes online immediately in the event of a master failure and subsequent recovery.
Which device and which configuration do you recommend?
Thanks Max
The "FLEX link" feature might match your purpose, as it is a layer-2 primary and backup link mechanism.
For more information, please reference our switch user's guide Chapter 29 (Page 200).
The switch model that supports this feature:
Please check which switch matches your network and feel free to ask if you have further questions.
Zyxel Melen0
Zyxel Melen0 -
Thanks for your support.
I bought a gs2220-10 to test.
I still have a question: how does the switch to know if the master is still working?
with ping? with snmp? other?
Thanks bye,
Max0 -
It is by link. The backup link will take over once the primary link's status turns down.
Zyxel Melen0 -
I tried the Flex Link setup in Zyxel GS2200-10HP and every thing works fine.
Thanks for your great support.Thanks bye,
Max1
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 491 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
