USG40W - When entering a website (www.idrive.com) I get redirected to the firewall login
2»
  • laltobelli
    laltobelli Posts: 24  Freshman Member
    First Comment Sixth Anniversary
    Apparently the USG40 does not block https websites. Which now adays is most websites, which makes it useless.
    Any further suggestions on the Indeed site?
    Larry
  • laltobelli
    Sorry, iDrive website.
  • laltobelli
  • laltobelli
    Apparently the USG40 Content Filter does not block https websites, which makes it kind of useless…
    Anyways any other ideas on why the idrive website gets redirected?
    PeterUK Posts: 3,891  Guru Member
    edited March 2
    Due to a change in web browsers the USG40 Content Filter may block only on the newer firewall models does it block.
    Still don't know why idrive website gets redirected have you tried seeing if uncheck "Enable HTTPS Domain Filter for HTTPS traffic" and reboot does any thing?
  • laltobelli
    Sorry about the delay in getting back, other fires to put out.
    I tried unchecking "Enable HTTPS Domain Filter for HTTPS traffic" and rebooting but it did not do anything. Same issue. This is really strange…
    edited March 22
    Yes strange DNS is correct so I don't get why your being redirected.
    Have you tested on other devices?
  • laltobelli
    Yes I tried on a couple of other PCs.
  • laltobelli
    The problem had to do with a port forwarding rule I put in. Disabling the rule allowed the website to open.
