[NEBULA] client pvn - establish but no route
FrankIversen
i have setup client vpn from a mac to nsg100 with nebula cloud auth.
It connects fine and i get the ip from the von-subnet i have defined.
but i can't seem to ping or make contact to our business lan.
is there any other settings we need to set?
I can ping from the NCC and down to the vpn client just fine.
Edit:
Works from iPhone but not from Mac.
Recommendation for Mac vpn client to try?
Edit:
seems something to do with macs in particular, maybe take a look at this? https://community.spiceworks.com/topic/425242-can-t-access-network-resources-over-vpn-on-a-mac?page=2
I would say probably change the priority of network in your mac and also enable "Send all traffic over VPN" see if it helps.
and FYI , there seems to be a problem with Macs if subnet IPs hav conflict2 -
Thanks! That was the solution, to move the VPN to the top of the service order.
Go to:
1- System Preferences
2- Network
3- Click the Cog / Tool menu drop down and select "Set Service Order"
4- Drag the VPN connection to the top.3 -
nice! glad I can help.
I guess apple products being too user friendly and features lead to these annoying things once in a while
- 245 Nebula Ideas
- 6.9K Security
- 813 USG FLEX H Series
- 393 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 543 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 125 Security Highlight
