redirecting http
Hi!
I have a webserver behind a zyxel 200H (frimware: V1.30) and I cant reach its website with its domain name/url, and instead of the website all I get is the zyxel 200H login screen.
I looked up the problem, and I should find a "HTTP Redirect" instruction on https://webhelp.zyxel.com/wohView/help_docs/USG110_V4.60_AAPH/index.html#page/ZyWall%20USG-VPN%204.60%20WH/h_Redirect.html
But on 200H I cannot find such as "Configuration > Network > Redirect Service "
or "Network > Redirect Service > Edit "
How can I reach the website and not the firewall with the website url?
Hi @Danee,
Please help to clarify:
- The direction of this issue is from the Internet to the web server's domain name?
- Is your NAT rule configured correctly?
Also, you might need to consider changing the firewall HTTP port setting to avoid port conflict. The path is Menu > System > Settings > Administration Settings
Zyxel Melen0 -
- on private IP alone: the website is not loaded from LAN,
in http://192.168.X.X:80 format: it is redirected to the firewall login screen, to the public IP address,
the sub.domain.hu format also redirecting the same way
So website is not loaded from LAN with IP, and redirected from WAN with domain name to the firewall webgui - NAT rule is:
Classification: Virtual Server
Incoming Interface: WAN
Source IP: any
External IP: INTERFACE IP, WAN
Internal IP: sub.domain.com (different domain ofc) with private IP
Port Mapping Type: Service
External Service: sub.domain.com TCP80-80 (range)
Internal Service: sub.domain.com TCP80-80 (range) - on System/Settings/Administration Settings:
HTTP/HTTPS enabled, on default ports
Changing the HTTP(S) ports would affect both the website and the firewall web GUI, wouldn't it?
0 - on private IP alone: the website is not loaded from LAN,
I'm sure in earlier firmware versions I tested this and it was fine I check again….
Edit update
so testing here it works fine GUI is port 80
NAT
Incoming Interface: ge2 WAN2
External IP: INTERFACE IP, ge2
Internal IP 192.168.255.193
Port Mapping Type port
Protocol Type TCP
External Port 80
Internal Port 80
NAT Loopback off
From my o2 > virginmedia > FLEX200H > HTTP server
and tested with NAT Loopback on
LAN 192.168.255.194 to WAN IP of HTTP server > FLEX200H > HTTP server
One thing you can try as I had it off is turn off "Redirect To HTTPS" for the GUI and reboot should not cause a problem but tried with it on without rebooting and was fine
Based on item 1, it seems so strange when a client is in LAN and tries to connect to the web server via IP address, and is redirected to the firewall.
Could you provide your configuration so I can reproduce this issue in my lab? Please send the configuration to me via private message. Also, please share a screenshot when you try to access the web server but been redirected to the firewall.
Zyxel Melen0
- 603 USG FLEX H Series
- 481 News and Release
