XGS1010-12 Port 9 No link speed leds or connectivity
mattsg9999
mattsg9999 Posts: 3  Freshman Member
Is port 9 disabled if using both 10gig sfp ports? Or do I have a bad port and it's RMA time?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,343  Zyxel Employee
    Hi @mattsg9999,
    Thanks for the update. Please reference this FAQ to submit an RMA request.
    Zyxel Melen
  • Zyxel_Melen
    Hi @mattsg9999,
    What device are you connecting to XGS1010-12 port 9? Could you try to connect port 9 and port 10 as a loop to check the link status and the speed?
    Zyxel Melen
  • mattsg9999
    Multiple devices. I just tried connecting 9 and 10 as a loop to check and there are no link speed lights at all. Connecting port 10 to one of the 1gig ports does light up link speed as 1gbps
    Port 9 seems completely dead
  • Zyxel_Melen
    Hi @mattsg9999,
    Zyxel Melen
