Unable to save/write startup configuration
Dylan96
Dylan96 Posts: 31  Freshman Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
It happens too frequently that after making any (any!) changes to the firewall configuration, this error appears:
In addition to losing the changes made, it forces me to reboot the device, which takes about 8 minutes!
Moreover, I cannot even restart it from gui or nebula, as the command remains suspended forever.
I have to log in via SSH and use the command ‘cmd reboot force’, as shown in the screenshot. Embarrassing.
USG FLEX 200H V1.31(ABWV.0)
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,529  Zyxel Employee
    Hi @Dylan96,
    Could you help provide us with a remote to check your device? You can reference this FAQ to set up and send me the IP and login credentials via private message.
    Zyxel Melen
  • kruess
    kruess Posts: 20  Freshman Member
    First Comment First Answer Friend Collector Fourth Anniversary
    Since over a year, Zyxel was not able to fix this really cumbersome bug… unbelievable. Some config changes here and there and boom. USG FLEX H was and stays a stillbirth, unfortunately. :-(
  • Zyxel_Melen
    Hi @kruess,
    We appreciate the valuable feedback you provided. However, we fixed a similar issue in the previous firmware version. This issue differs from the last case because the error codes are different, even though the error message remains the same. Remote access will be very helpful in investigating this issue.
    Zyxel Melen
