WiFi upload is to slow
Rocki
Rocki Posts: 2  Freshman Member
Hello, I have a problem, everything was fine yesterday, now I can't use the internet normally...
The internet router was connected a couple of days ago.
Download 90
UPLOAD IS 8 can you help me please
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,292  Zyxel Employee
    Hi @Rocki,
    What's your device? Since it is WiFi, you need to check if the signal strength is good and the channel utilization is low. Channel utilization will affect your network quality. In our experience, channel utilization that is lower than 60% will result in better network quality.
    Zyxel Melen
