500H - Error while DDNS updating
500H - This is the error randomly shows from the gui when i try to manually update the ddns
Hi @Mk88_it,
I'm checking it with our engineer. In the meantime, may you enable Zyxel support access so I can confirm and record a video of this issue? The issue site is the same as before, is it correct?
Zyxel Melen0 -
Hello @Zyxel_Melen yes it's the same site but this issue there was before the firmware update to V1.31(ABZH.0)ITS-0227-GUI. You should be able to connect to our 500h with your dedicated access with anydesk
Hi @Mk88_it,
Thanks! I have asked our engineer to check this issue. I will keep you posted.
Zyxel Melen0 -
Hi @Zyxel_Melen I saw you were working on our 500H remotely. I would like to specify that the error message appears only when you click on the update button
Maybe to error happens with a PPP as backup?
I tried with other wan interfaces before this configuration but the error was the same. It only appears when I click the button Update to force the job. The workaround that I found to temporarily solve the situation is to edit the profile with everything you want and save, then re-click the button Update and it works.
I have not seem this error when using the update button in DDNS....maybe the name you have given the interface is a problem?
or maybe try with only primary and Auto?
I have no ideas at the moment, i've tried with different profile/interface names too… after lot of troubleshooting I decided to open this discussion. Zyxel's engineers have been connected to our device for last few days and I think we have to wait a response form them. @Zyxel_Melen do you have any updates?
Hi @Mk88_it,
Thanks for the previous message. We know this issue occurs after clicking the "Update" button. Unfortunately, we need to upgrade a debug firmware to collect more details. I will directly upload the debug firmware to the AnyDesk PC.
Zyxel Melen0 -
Hello @Zyxel_Melen, I just installed new code firmware V1.31(ABZH.0)ITS-m7615-250101359 provided to me by @Zyxel_Judy , but the DDNS update issue is still present.
- 430 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 353 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 82 Security Highlight
