NWA130BE: Homekit not responding when DNS Threat/IP Reputation Filter enable.
My network consist of 2 switched (XMG1915-10E and GS1915-8) that are located in 2 different rooms. All devices have a NCC pro license.
On my main switch (XMG1915-10E) I have hooked up my access point (NWA130BA) and on the other switch is my AppleTV. This apple TV is my homekit hub for all my lights.
However, when I switch on DNS Threat/IP Reputation Filter (Configure/ access point /security service), the homekit devices stop responding.
I would like to use the DNS protection, but I have no idea what the issue might be.
Anyone had this issue or knows how to solve it?
Thanks,
Jurgen
Hi @JurgenS,
You can check the event log to find which domain/IP was blocked.
Then set it to the allowed list.
If you need any further help, please enable Zyxel support access so we can help check this issue.
Zyxel Melen0 -
Goodmorning,
I tried as suggested and did not find any DNS threat blocks that are linked to apple/homekit.
We noticed also that some icloud functions are not working as aspected when DNS Threat/IP reputation filter is enabled. One example is managing our daugthers screen time through Icloud.
And in the mean time I also found that my company's VPN does not function when this filter is enabled. No blocked DNS's/ip found in this case.
I will enable Zywel support access since I am unable to find any reason for this behaviour.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
