Problema WiFi con USG20W-VPN
Hi @InsideSrl
Could you help to refresh the Nebula control center? This might be a cache issue.
Zyxel Melen0
Hi @InsideSrl,
Votre SSID est toujours inactif puisque vous avez mentionné que le voyant WLAN est éteint. Veuillez vous assurer d'avoir appliqué la configuration après avoir activé votre SSID.
Your SSID is still inactive since you mentioned the WLAN LED is off. Please ensure you have applied the configuration after activating your SSID.
Zyxel Melen0 -
Hi
the problem is on nebula interface and is enabled
Hi @InsideSrl,
Please help to navigate to Site-wide > Configure > Firewall > Wireless.
The page you screenshot is for AP, not for USG20W-VPN.
Zyxel Melen0 -
Sorry but on
Configure-firewall there'isnt wireless0 -
Hi @InsideSrl
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
