Zyxel vmg3925-b10b default password
aptanet
in Home Router
I have reset my vmg3925-b10b router to use as a backup, but am now unable to login. I have tried the suggested options of admin with 1234, password or admin, but they don't work. My original password also does not work now. Is this now bricked or are there alternative methods of regaining access to configure it?
Have you check wtih your ISP yet? sometimes, it might have its own password on the device rather than what it is on the label.
I haven't managed to as this router was provided before a connection change, and the ISP has merged with another. Worth a try though. It is only really a backup. I may see if I can flash a new firmware onto it, although that may be blocked.
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 499 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
