Lock out of Management VLAN - what am I doing wrong?
I know I'm making a mistake, I asked ChatGPT, I looked on Google, I can't pinpoint the issue.
I'm trying to change the management VLAN.
I connect via cable with my Laptop to 192.18.1.3. All perfect.
I create VLAN 381.
I go to web interface, I assign port #07 as "Untag Egress Member". Moreover, I assign port #06 as "Tag Egress Member" (See pic1).
I go to "Management" and I change the Management VID to 381 (See pic2).
Then I get this warning
I click OK.
I connect my laptop to port #07 - nothing. I connect to port #06 - nothing.
There are no other devices in the network, just my laptop and the switch.
I change nothing else.
What am I doing wrong?
Hi @zyxel1,
You need to notice:
- PC can't understand the VLAN tag, so you should connect it to port 6(untagged port).
- You must change port 6 PVID so your PC will truly belong to VLAN 381.
- Since you only connect your PC to the switch, you need to ensure your PC has an IP address and is 192.168.1.X/24. Then, you can access the switch (192.168.1.3).
Zyxel Melen0 -
You have to do it in order
so default
PVID 1 on all ports
VLAN 1 all ports untagYou connect to port 6 to get to the UI
You add VLAN 381 non-member 1-6, 8-12 untag 7 with port 7 PVID 7
On VLAN1 change port 7 non-member
Change management VLAN to 381 you will then need to change over to port 70
- 441 Beta Program
- 292 Service & License
