500H - Error while DDNS updating
Mk88_it
Mk88_it Posts: 75 image  Ally Member
500H - This is the error randomly shows from the gui when i try to manually update the ddns
«1
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    Hi @Mk88_it,
    I'm checking it with our engineer. In the meantime, may you enable Zyxel support access so I can confirm and record a video of this issue? The issue site is the same as before, is it correct?
    Zyxel Melen
  • Mk88_it
    Hello @Zyxel_Melen yes it's the same site but this issue there was before the firmware update to V1.31(ABZH.0)ITS-0227-GUI. You should be able to connect to our 500h with your dedicated access with anydesk
  • Zyxel_Melen
    Hi @Mk88_it,
    Thanks! I have asked our engineer to check this issue. I will keep you posted.
    Zyxel Melen
  • Mk88_it
    Hi @Zyxel_Melen I saw you were working on our 500H remotely. I would like to specify that the error message appears only when you click on the update button
    PeterUK Posts: 4,268 image  Guru Member
    Maybe to error happens with a PPP as backup?
  • Mk88_it
    I tried with other wan interfaces before this configuration but the error was the same. It only appears when I click the button Update to force the job. The workaround that I found to temporarily solve the situation is to edit the profile with everything you want and save, then re-click the button Update and it works.
    edited March 7
    I have not seem this error when using the update button in DDNS....maybe the name you have given the interface is a problem?
    or maybe try with only primary and Auto?
  • Mk88_it
    I have no ideas at the moment, i've tried with different profile/interface names too… after lot of troubleshooting I decided to open this discussion. Zyxel's engineers have been connected to our device for last few days and I think we have to wait a response form them. @Zyxel_Melen do you have any updates?
  • Zyxel_Melen
    Hi @Mk88_it,
    Thanks for the previous message. We know this issue occurs after clicking the "Update" button. Unfortunately, we need to upgrade a debug firmware to collect more details. I will directly upload the debug firmware to the AnyDesk PC.
    Zyxel Melen
  • Mk88_it
    Hello @Zyxel_Melen, I just installed new code firmware V1.31(ABZH.0)ITS-m7615-250101359 provided to me by @Zyxel_Judy , but the DDNS update issue is still present.
