Problema WiFi con USG20W-VPN
InsideSrl
InsideSrl Posts: 7 image  Freshman Member
Buongiorno ho un problema con un USG 20W
S232L09101076 (USG20W-VPN)
Ho abilitato il wifi con SSiD e il nome non appare nella lista dei dispositivi wifi, oltre a non accendersi il led WLAN sul dispositivo
Grazie
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,613 image  Zyxel Employee
    Hi @InsideSrl
    Could you help to refresh the Nebula control center? This might be a cache issue.
    Zyxel Melen
  • Zyxel_Melen
    Hi @InsideSrl,
    Votre SSID est toujours inactif puisque vous avez mentionné que le voyant WLAN est éteint. Veuillez vous assurer d'avoir appliqué la configuration après avoir activé votre SSID.
    Your SSID is still inactive since you mentioned the WLAN LED is off. Please ensure you have applied the configuration after activating your SSID.
    Zyxel Melen
  • InsideSrl
    Hi
    the problem is on nebula interface and is enabled
  • Zyxel_Melen
    Hi @InsideSrl,
    Please help to navigate to Site-wide > Configure > Firewall > Wireless.
    The page you screenshot is for AP, not for USG20W-VPN.
    Zyxel Melen
  • InsideSrl
    Sorry but on
    Configure-firewall there'isnt wireless
  • Zyxel_Melen
    Hi @InsideSrl
    Zyxel Melen
Nebula Tips & Tricks
