WIFI mesh with cabled accespoints
JanJ
JanJ Posts: 6 image  Freshman Member
Hi
I want to create wifi network were 3-4 access points are connected with cables and roaming between stations is possible. Network can be chained or distributed in shape. Unfortunately I'm not able clarify how to make this with zyxel devices. Can some help in this?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,319 image  Zyxel Employee
    Hi @JanJ ,
    While your statement about "Network can be chained or distributed in shape" isn't entirely clear to us, we understand that you likely want your access points connected to your router or switch via Ethernet cables, allowing wireless clients to roam seamlessly between APs as they move.
    To achieve this seamless roaming, please ensure:
    1. All access points broadcast identical SSID names and use the same security method (such as WPA2-PSK)
    2. Access points have overlapping coverage of 15-20% between devices
    You can create the SSID and configure security settings in Standalone mode by following these instructions:
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @JanJ ,
    Zyxel_Judy
    Untitled Image
