Cloud CNM 3.1.1 device status
Hi @Vadim
After device managed by SecuManager, then will send periodic inform to server side per 900 seconds. If fail for 2 times, then server side will shows offline.
You may further checking on the internetworking stability and also see if this symptom disappears after rebooting the USG40
Yes, all what you say is true and works fine. All devices configured with daily reboot. But this one was offline without any connections and without power. So, then how CloudCNM shows "online" status if this device didn't send any connection requests in 4 days?
Hi @Vadim
I will send you private message for check this issue more details.
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
