ZyWALL IPSec VPN Client
i've installed ZyWALL IPSec VPN Client to do a VPN connection with a ZyWALL 370 VPN.
Kind of connection is IKEv2. but, i've a question with the VPN configuration, i should give an IP (client VPN address) otherwise the ZyWALL IPSec VPN Client get an IP : 10.20.20.10. I don't understand why, where are from this IP 10.20.20.10. Is it possible to setup a range of IP address in the VPN and where ? I would like that the ZyWALL IPSec VPN Client get an IP like 192.168.253.0/24 range
The second thing is that i have several IPSec VPN tunnel (site to site) and when i connect the ZyWALL IPsec VPN Client without client VPN address (0.0.0.0), the client get the IP 10.20.20.10, i don't know why but i've a VPN site to site who fall the connection (only one) .
Thanks a lot.
Hi @steve15f
Welcome to Zyxel community.:)
If you would like to get IP address from ZyWALL, then you must enable EAP in VPN Gateway(phase 1) and configuration payload in VPN Connection(Phase 2).
ZyWALL Phase 1: extended Authentication Protocol
ZyWALL Phase 2: Configuration Payload
IPSec VPN Client Phase 1:
IPSec VPN Client Phase 2:
After tunnel established, then you will get IP address and remote LAN subnet automatically.
5
Hi @steve15f
5 -
Thanks a lot0
- 3K Nebula
- 231 Nebula Ideas
- 6.6K Security
- 672 USG FLEX H Series
- 360 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 500 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
