Info on NWA210BE - NWA130BE -AX3000
Gru_Ma
Gru_Ma Posts: 15 image  Freshman Member
Hello
we are planning a new wifi network, these models regardless of performance can create a local mesh network or only via nebula? Thanks
We are planning to install also a zyexe firewall
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 410 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Hi @Gru_Ma,
    It's good to know that you're interested in our products.
    The NWA130BE and NWA210BE can have Mesh in both stand-alone and on-cloud.
    Here's the guide to show you how to create Mesh in stand-alone.
    And here's the guide for the on-cloud.
    Thanks.
    Ivan Liu
  • Gru_Ma
    edited March 2025
    Thanks for your help
    The nwa90ax-pro Can be make Mesh in stand alone ? And for NWA130BE Which power Supply?
    thanks
  • Zyxel_Ivan
    Hi @Gru_Ma,
    The NWA90AX-Pro is also available for the MESH.
    The power supply for NBA130BE is PoE (802.3at): power draw 24 W, DC input : 12 VDC 2A.
    Thanks.
    Ivan Liu
