How To Add FQDN fo Viber and Wechat in ATP 700
SalaiRobin
SalaiRobin Posts: 2 image  Freshman Member
edited March 18 in Security
I already added FQDN for Viber app but can not connect. I want to setup to allow Viber and Wechat for user
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    Hi @SalaiRobin,
    Have you checked the logs if the traffic has been blocked by any security policy? By default security policy, these apps should be able to use.
    Zyxel Melen
    PeterUK Posts: 4,268 image  Guru Member
    edited March 17
    you may what to try
    *.Viber.com
    then clear DNS cache on PC and USG
    it can be hard to allow a App by FQDN due to the APP may use a IP not done by DNS
  • SalaiRobin
    I already test, it doesn't work.
  • mennogeek
    mennogeek Posts: 1 image  Freshman Member
    I would use the Content Filter service instead of fqdn for this.
  • Zyxel_Melen
    Hi @SalaiRobin,
    Zyxel Melen
