GS1920-24HP - Firmware Upgrade Issues.
Posts: 6  Freshman Member
I tried to add a comment to the below thread as it was very similar to mone but could not so I have had to create a new post, apologies.
I have renamed the new firmware file 480ABMI1C0.bin to ras-1 and tried to use ftp and WinSCP to transfer them over to the switch.
Via FTP, I get the error "-10 File Size Too Large"
Using WinSCP, first I tried uploading the file and I get "Received SSH"_MSG_Channel_DATA for nonexistant channel 0"
Then I tried deleting ras-1 directly from the switch using WinSCP and I get "The server does not support the operation"
Doing a bit of research it all points to the switch not having enough free space on it, though I may be wrong.
Any help would be appreciated, thank you. Screenshots attached. Adrian.
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
Welcome!
Welcome!
