GS1920-24HP - Firmware Upgrade Issues.
I tried to add a comment to the below thread as it was very similar to mone but could not so I have had to create a new post, apologies.
I have renamed the new firmware file 480ABMI1C0.bin to ras-1 and tried to use ftp and WinSCP to transfer them over to the switch.
Via FTP, I get the error "-10 File Size Too Large"
Using WinSCP, first I tried uploading the file and I get "Received SSH"_MSG_Channel_DATA for nonexistant channel 0"
Then I tried deleting ras-1 directly from the switch using WinSCP and I get "The server does not support the operation"
Doing a bit of research it all points to the switch not having enough free space on it, though I may be wrong.
Any help would be appreciated, thank you. Screenshots attached. Adrian.
Hi @iComms,
Regarding your description, this is more likely because your GS1920 is a V1 version. Could you share the serial number for me to check?
Please be aware that the GS1920 v1 model has reached its EOL status. For optimal performance and support, we recommend exploring our current switch offerings here:
Zyxel Melen0 -
Thanks Melen, we have 2 of these:
S172L06001590
S172L03003521
How do we get these on the latest firmware?
Adrian.
Ignore me. Found the firmware for V1. Adrian.
Back again - cannot find the latest firmware for our v1 switches in the EOL section.
GS1920-24HPv1
Anyone know where we can find this?
Currently on:
V4.50(AAOC.3) | 05/20/2020
Thank you.
Adrian.
Found it:
And after all that we are on the latest firmware already 😂
Adrian.
- 601 USG FLEX H Series
- 480 News and Release
