Email notification sent to a DEACTIVATED admin
GiuseppeR
GiuseppeR Posts: 663 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
I set an Organization with 2 sites with alerts to all admins:
I have deactivated an admin:
Anyway the "orange" admin is still receiving email alerts.
It seems strange to me this behaviour.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    Update:
    This issue has been fixed on 2025/04/22.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR,
    Let me help to check with my team if this is an issue. I will keep you posted.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR,
    After checking the specs and doing local tests, this issue didn't occur on our side.
    I will send you a private message to request the detailed information.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR,
    Thanks for the information via private message. This issue has been addressed and will be fixed next week.
    Zyxel Melen
  • GiuseppeR
    Hello @Zyxel_Melen
    you are welcome, I'm at your disposal. See you soon
  • Zyxel_Melen
    Update:
    Zyxel Melen
Nebula Tips & Tricks
