500H - Error while DDNS updating
2»
  • Mk88_it
    Mk88_it Posts: 76 image  Ally Member
    Hello, can I have an answer please? We need this feature to work fully!
  • Mk88_it
    To temporarly fix the problem, I have to change something in the "failover" profile and save. After that, the profile works as expected
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,600 image  Zyxel Employee
    Hi @Mk88_it,
    I apologize for the delayed reply. Could you share the configuration of the issue with us so we can compare the differences? We also checked the previous configuration file. Is the "HTTPs" option the difference between the issue and the no-issue configuration?
    Zyxel Melen
  • Mk88_it
    Hello @Zyxel_Melen, I sent a private message to you about that
  • Mk88_it
    Hi @Zyxel_Melen  the ddns issue still persists even with 1.32 firmware
    To solve the issue, i must edit the profile changing something, save the profile and then It works for a while or until next reboot.
  • Zyxel_Melen
    edited June 2025 Answer ✓
    Update:
    This issue has been addressed on V1.32 and will be fixed in the next firmware release.
    Zyxel Melen
