XGS1250-12 Ports 9 & 10 offline after Power Cut
Hi
I have a XGS1250-12 bought in April 2024 so still under warrenty. Its fully populated with a mix of 1Gb/s, 2.5Gb/s & 10Gb/s including a SFP+ with a 10 Gb/s connection.
I use it in my study with the following devices
10 Gb/s connections going to NAS devices and my PC.
2.5 Gb/s going to Mac Mini & Intel NUC Server via a USB 2.5Gb
The remaining 1 Gb to printers, scanner, sky box etc.
We had a power cut last week and both ports 9 & 10 have stopped working, 11 & 12 are OK as is 1 to 8, just 9 & 10 have failed.
I have power cycled the switch, checked port settings, changed them and forced a reboot, after reading other peoples posts who have had the same problem I have plugged a cable from one of the working 1 Gb/s port into 9 & 10, with no luck.
Any ideas what I can try next?
Adam
Hi @AdamBrighton ,
Could you loop ports 9 and 10 to another port to check if they come up? If they don't work, please use this link to contact our local support directly for RMA assistance.
Zyxel_Judy
Hi @AdamBrighton ,
Zyxel_Judy
Hi
Thanks for the reply, Port 9 came back to life, but 10 seems dead.
I will check out the RMA link.
Regards
Adam
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
