MPro Mesh App Parental Controls Bug
WildSnowStorm
in Home Router
I have a MPro Mesh App to control my Trooli FTTP EX5601/EX5600-T Router. Which is all running well on 26 devices but as soon as I try and link my Sons Meta Quest 3 to lock down the hours it selects another device on my list. This can be at random but it just doesn’t seem to want to add the Meta Quest 3 to the group. As below.. select Meta 3 and then further up the list Wilbur’s Echo is selected. If I unselect it then it unselects the Meta.. any Ideas??
I would suggest to check with your ISP to see if they have see others reporitng similar issue or not. at the moment, add one device and the other.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
